dont be afraid of the dark you wuss!
hahahahaha some ones come back yaaaaahhhh hahahahahahaha hey if ya going this time leave the light on lmao :bananaman
it sad when u have to resort to things like this hahahahaha
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hey erin what the go with that U never answer me when I talk to u in here???? :D
Have I done something to offend you in some way ??:Paranoid:
Nah I an sure it's not you , She goes back a few pages like I do to when I was last on , and read everything up till now to catch up on all the goss , it can take a while , and ppl see your name think you are on that page when you are back 10 pages , happens to me alot
so better get my whorin in now as i am going camping!!! ACK better take my spare batteries for the laptop, still no net access for 2 days, I dont know how I am going to cope, thank god for 6 hour length batteries, 5 should about do it :D
I
am
so
bored
that
I
am
going
to
post
this
extremely
elongated
post
just
to
see
how
much
longer
I
can
make
the
page
go
for.
So
far
so
good
but
I
wonder
if
this
will
annoy
a
mod
to
delete
it.
Also
I
wonder
if
those
that
get
email
updates
of
this
thread
will
get
a
stupifyingly
long
email?
Well
I
am
not
stupid
enough
to
have
email
updates
of
the
whore
thread,
why
when
I
spend
90%
of
my
life
in
here!
:D
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
