  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
There was a moment last night, when she was sandwiched between the two Finnish dwarves and the Maori tribesmen, where I thought, "Wow, I could really spend the rest of my life with this woman".
how funny is the walk off scene in that movie?
There must be more to life than being really really good looking.
hey cyrus how I do lock down a PC so no-on can change jack shi7 on it without my permission? I know you've done it to all the PC's where you work.
Welcome to my area of expertice, I AM THE ULTAMITE NETWORK ADMIN NAZI!
Depends on wether your network makeup.
Is it domain or workgroup based?
Was OS are they running 98 or 2000/XP?
Oh ad:
Uhh Earth to Matilda, I was at a day spa. Day, D-A-I-Y-E. Okay?
Workgroup is slighty harder, but if they arent any 89 that is good poledit is a bitch!
Anyway what you need to do is setup a machine and set all the group policies for the local usergroup, this takes the longest because you can set access for nearly every single one of windozes fifty bagillion settings.
Once you have created this group policy then you'll have to go to each machine and apply it to the local machines user group and then add the user to that group.
Much easier if you were domain based, all done on the PDC and it flows through to all puters in seconds :P mUAhAH HAUUhAHu AHH H ahH H Ah HA hAH H AH h A hAH HAH AH HA h Ah AAaaa!!
If there is anything that this horrible tragedy can teach us, it's that a male model's life is a precious, precious commodity. Just because we have chiseled abs and stunning features, it doesn't mean that we too can't not die in a freak gasoline fight accident.
Well, I guess it started during my first year of the second grade, when I was eating lunch and caught my reflection in a spoon, and I thought to myself, 'Hey, Derek, you're ridiculously good looking! And I thought maybe I could do that for a career.
Do what for a career?
Be professionally good looking.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
