I do sunshine coast to tweed heads, plus a lot of stuff out west...
Noosa, Tweed, Burleigh, Mooloolaba, Dalby, Warwick, Toowoomba, Stanthorpe, Surfers, Brisbane (north and south, dur), Caboolture, Morayfield, Redcliffe, Caloundra, Dinmore, urgh far too many places to list.
Some weeks I hit the 1000k mark :D I've done 62,000k in my van and its just hit the 2 year mark. I'm not even a bloody delivery driver! :P
hahahahahahaha hey andrew u think that a lot the ute I have hase got 140,000 km on the clock & its a 7/02 :D lmao
yeah 1000km mark is easy I do 300+ every day
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
How can you drive soo much for your job, then get in a car and enjoy driving on the weekends?
When i used to work in the city, I used to bus it to and fro and I used to look soo forward to driving my car on the weekends.. Now it's like.. do I have to get into it again?!2
hay Ben I think there is a cruise tonight , but I am broke after the intercooloer today , if you could sapre a little cash I will come get you.?? I need to show this off!!
lol easy erin when the car is going its easy any way its a bitsamissen I drive at work lol not a nissan :P as some ones sig says "COME ALIVE COME & DRIVE A NISSAN" + how could I miss out on all the fun
Yeah, but I've got to try and fit work in around all my driving! Thats just driving to GET to the job, not including the job itself!
For a while there I was using a tank of fuel a day :P Thank christ some of the further out ones (ie: stanthorpe) havent broken down in a while, I'm sick of driving
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
    • I'm looking for a direct bolt on turbo upgrade for my 93 R33 GTST.  Anyone have experience with this Greddy T620Z turbo upgrade? I'd like to be able to run about 300hp to the rear wheels without putting too much strain on the turbo. I do daily drive the car.  Pretty stock car with basic bolt ons (exhaust outlet, down pipe, high flow cat and catback exhaust along with intake and FMIC).  I'l probably have a Haltech plug n play on the car before installing the turbo. https://www.greddy.com/products/turbo-upgrade-ecr33-er34-t620z-rb25-11520057   Also, any thought on this much boost on a 30 year old motor with 250,000KMs?  Engine feels/sounds strong for what it's worth.   Thanks you in advance!
