  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
lol.. well if all goes well I will probably take some pix tomorrow, post them up.
It's not going to be complied (going to do that mostly myself I decided) for a while, so not going to go anywhere much further than the driveway unfortunately :(
Yeah same here I hate buying pos cars and spending money fixin this and that, rather just spend more money and buy something that is gonna last and stuff.
thats why i sold the line and bought a new car for work i would have loved to keep the line but i didnt want a shitbox ute that would break down on me everyday i went to work so i bought brand new instead
Yeah what you got is waaaaaay better than a pos ute, although I know of some pos utes that just refuse to die, so but still I'd rarther what you got to over a pos ute, but hmmmm add in a skyline and it would be a tough call for me, but you probably made the cheaper decision which in the end would be the right one :(
And no sign of Nexus at the meeting :( NO HUB AND NO CAT5 CABLE MAKES CYRUS something something
Sorry Cyrus I am sick, I had to have the day off work today as well and I never take days off :D
new car is black..
yeah, chris didn't sound too well this morning... Didn't think he would make it.
I yes and no about shitboxes.. they're never anything classy, but parts are cheap, and my last 4 shitboxes have only broken down on me twice.. once for a dead starter motor, and once for a dead cas.. but I do try to choose my cheap crap carefully :(
And if one can do 15 laps of QR without dying they can't be that unreliable :D
yeah i had to way everything up aswell 2 regos 2 services tyres petrol it all was to expensive
Yeah yeah yeah!
You've been out galavanting all over the countryside with that floosy of a big brother of yours! Havent you! Havent you! Look at meeee! :(
Yeah Gordo said you musta been pretty sick, I'll just grab it off ya some other time, no biggie, go back to bed and drink some more chicken soup, it's easy on the toncils as you throw it back up :D
ahh yes congrats cyrus
couldnt get there to vote tonite had my touch semi on
Yeah I'll forgive you this time! :( Anyway there wasnt much voting :D more along the lines of, hey you want to be president, fine there ya go, who wants dibs on treasurer, Bam there ya go, anyone else, oh yeah secretary, cool no probs!
Was pretty straight forward, no real need for voteing, I just suggested it for my sake so that people cant say I didnt get voted in but was appointed the position :D
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
