  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
My family loves it when I'm around and theres prawns, cause I like peeling them, and they like eating them :P
So it's win win for everyone!
Rip their heads off and suck their guts out!
i hate this week!
i been at work for the past 9 days over the xmas break. 12hrs a day + more.
now taking 2 weeks off. going to be sitting by the beach and fixing up car. got pics from the storm up here now. from the weekend
dont think about work... its a bad thing to do on holidays.. think of what you can do during the day while you are enjoying your holiday. think about work the day you go back. works a treat for me.
Cheap... I like it :D
Pfft, holidays, what are they? I'm at work right now (ahem) setting up a sysprep Win2K image. Yay. And my sunroof leaks now too, due to damage caused by (I suspect) a vandal while it was parked... :)
Be careful theres no tsunamis!
yeah true... and the sharks... and the cancer causing sunburn.... and the drive to the beach and possible car park rage.
stuff this i am staying home and swim in the backyard pool :)
True true.
I'm going to get my hair done today :) And then.. not sure. Andrew wants to go for a drive tonight, but I'm sick of driving, the amount I did on fri/sat/sun last weekend was bullshit.
hair done? isnt that like 3-4hrs in the comfy chairs chatting and having coffe and getting pampered...
guys idea for a haircut is in and out in 15min... mmmm might be onto something there :think:
Pfft, holidays, what are they? I'm at work right now (ahem) setting up a sysprep Win2K image. Yay. And my sunroof leaks now too, due to damage caused by (I suspect) a vandal while it was parked... :D
oo unlucky... people have no respect nowdays for cars :)
Hahah.. Soo true. I have to get my re-growth done again. My sisteres a hairdresser so 2 hours worth of work to my hair costs me $5 .. but only when she asks for money cause her boss is there. I normally get about $100 worth of stuff done. It's awesome having a sister as a hairdresser. Cept when I was the guinea pig. Back in 1996.
Andrew will probably get his hair cut too. 10 minutes :)
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
