  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
My family loves it when I'm around and theres prawns, cause I like peeling them, and they like eating them :P
So it's win win for everyone!
Rip their heads off and suck their guts out!
i hate this week!
i been at work for the past 9 days over the xmas break. 12hrs a day + more.
now taking 2 weeks off. going to be sitting by the beach and fixing up car. got pics from the storm up here now. from the weekend
dont think about work... its a bad thing to do on holidays.. think of what you can do during the day while you are enjoying your holiday. think about work the day you go back. works a treat for me.
Cheap... I like it :D
Pfft, holidays, what are they? I'm at work right now (ahem) setting up a sysprep Win2K image. Yay. And my sunroof leaks now too, due to damage caused by (I suspect) a vandal while it was parked... :)
Be careful theres no tsunamis!
yeah true... and the sharks... and the cancer causing sunburn.... and the drive to the beach and possible car park rage.
stuff this i am staying home and swim in the backyard pool :)
True true.
I'm going to get my hair done today :) And then.. not sure. Andrew wants to go for a drive tonight, but I'm sick of driving, the amount I did on fri/sat/sun last weekend was bullshit.
hair done? isnt that like 3-4hrs in the comfy chairs chatting and having coffe and getting pampered...
guys idea for a haircut is in and out in 15min... mmmm might be onto something there :think:
Pfft, holidays, what are they? I'm at work right now (ahem) setting up a sysprep Win2K image. Yay. And my sunroof leaks now too, due to damage caused by (I suspect) a vandal while it was parked... :D
oo unlucky... people have no respect nowdays for cars :)
Hahah.. Soo true. I have to get my re-growth done again. My sisteres a hairdresser so 2 hours worth of work to my hair costs me $5 .. but only when she asks for money cause her boss is there. I normally get about $100 worth of stuff done. It's awesome having a sister as a hairdresser. Cept when I was the guinea pig. Back in 1996.
Andrew will probably get his hair cut too. 10 minutes :)
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
