  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Evah seen a 4 door auto N/A R32 do skids? It's funneh says:
I <3 cyrus.
Cyrus - Ska - Drift0r - Beggar Extraordinaire! says:
Wassup biatch?
Playing with my oversized penis.
Love your work, pics or ban.
Yeh, here you go.
Oh your so big and bad.
I try my hardest to impress my biggest fan.
A weekend in the life of V8skylineMAN:
Here is a list what i have done to that in the last three days
motor in....
crank is different...fark...need manual
get clutch fit clutch
get pedal box and clutch master and slave cyl from r31 and 200b and modify to suit application
manual in...
all anciliaries bolted to motor
gearbox is 5inches shorter than the auto
fark....manual out.....run around like an idiot looking for a long 5speed(impossible to get one atm)
find out that crank is NOT different...
there is an adapter on the end of it....pulls off with two tyre levers
put auto back in....
realize that i cut all the lines that the auto uses when i took it out as i wasnt using it
run around like an idiot again to find the cooler lines...
find some at murrarie.
remove clutch master slave and pedal and go get auto lines.
fit auto lines to gearbox....remember that the motor doesnt have an oil pickup in it yet...
undo engine mounts
lift engine and remove sump....
go 1/2 way to toowoomba to get oil pickup
fit oil pickup
fit sump...lower engine....do up engine mounts...
fill with oil...fill auto with tranny fluid
fit tailshaft
try to start car,,,....nothing
find that wiring is all wrong on the auto...
fix wiring...try to start car....
car starts.!!!....exaust isnt done up.....FARK its loud!
turn car off.
fit exhaust
start car.....runs on 5 cyls only.....
begin diagnosis
find that no2 cyl is not firing.....
plenty of spark.....
check exhaust....no popping....not a valve
must be fuel suply to Injector....nope...plenty of pressure..
guess that injector must be the problem...remove injector(cvnt of a job)
replace injector
start car...WOOOOOO firing on all six!
fit radiator and hoses
fit fan
fill with coolant
let the car idle for 20 mins
not getting hot, go for a small drive....temp on 1/3....sweet
sit down and relax
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
