  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Attention Councillor Revhead
It has come to my attention that you may have become a victim of identity theft as per here....
http://www.skylinesaustralia.com/forums/me...php?userid=1965
As we all know the dangers inherrent in the use of the internet and the need to take care when giving out personal information, it does not however give someone the right to steal someones identity in the event such care has not been taken.
I hereby propose that the council bring the full weight of our displeasure against this identiy thief.
What say you councillors?
THIS IS AN OUTRAGE!!
I say we vote this so called Councillor Blade out of parliment Immediatly and charge him with conspiracy.
Ahhh so the vanes have become entagled in a bitter union dispute and have elected to strike. Are they carbon vanes? As I have also encountered these lazy uneducated souls and been most dipleased with there efforts of past.
Councillor hottie, I agree we should stomp on these identity theves, possibly by numerous assaults wherever they post
Aye... Assualt at will...
Whilst I appreciate the immediate attention your goverment vehicles require I must protest that my vehicle has been quite sluggish of late and it requires the most urgent recognition. I failed to beat an opposing parties vehicle the other day whilst travelling on my funded trip to brisbane. Notwithstanding the opposing goverment was of the toyota party, the supra electorate to be exactl, I feel that my clutch device may be not be functioning to its full potential as it begins to slip upon full accelaration in the final gear of 5th....I move that all the governments vehicles be reviewed and if need be fixed until they are of the highest possible standard required to be superior to any other party.
this identity theft is a ludacris act and it must be stopped by heavy handed action. I belive the councillors alias is blade and all must do what they can to stop any further infiltration of our government.
In furtherence to the identity theft matter, the pressure has started to be applied, but there has been no action as of yet from the respondent.
This action requires more resolve from the council members and more support for our council bretheren.
Register your displeasure here http://www.skylinesaustralia.com/forums/sh...ead.php?t=63338
Councillor Batwing, this is the second compressor thing I have bought for the government vehicle to replace the original broken one that we won't go into the story of.
Because of budget cuts, I was informed that I should purchase a second hand compressor from a "wreckers" which only lasted 3 weeks until it broke in the same manner as the original compressor.
The airconditioning in my government funded car is still functional, it just isn't functional when sitting still at sets of lights.
I councillor batwing graciously accept the new title you have bestowed upon me. My heart goes out to the member for psi and all the other party members living on the breadline whose vehicles have sub funcional climate control.
I am absolutely appauled at the misuse of my rather gorgeous profile. As such I have made my demands in the offender's thread and expect a package in the mail any day now. If said package is ticking, I shall call a meeting to discuss.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
