  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
mindflux: sounds like it.. basically if you apply light throttle the boost will all leak out and will struggle to hit "full boost" where it should. If you boot it, generally the force will be enough to squeeze air through all the piping even if leaking, but it will still be down on what it should be doing.
I experienced the same a couple of months ago. Ended up being my rubber intercooler elbow had split. Was pissing out heaps of boost (could literally feel it when I put my hand there). I mean I was getting 10psi of boost or whatever it was set to, it just wasn't doing it properly or efficiently and the turbo was working harder than it needed to. Replaced it and fine again.
Went up to DMD and got my front bar fitted today... its straight out of the mould, so in need of some white paint :D Gordo, up for a group buy and panel painting??? haha
Took me 2 hours to get there, thanks to running into cops on the way, I wont go into details on a public forum, I can say though I received 2 seperate fines... Will have to have a chat with everyone tommorow night to work out if I can challenge it all...
as matt said..
hey, just read that last post .. cop trouble huh? doesn't sound good!
yeah, to be honest I wasn't happy with the quality of my sideskirts that came out.. i had to spend an hour or so sanding it back today -- all the rough edges. Somebody said all DMD stuff came "pre-prepared". Not from what I got. Anyhow, will look good when done which is all i'm worried about.
as matt said..
Yeah i was pretty pissed at the run in with the cops, oh well, 15 months or so with a skyline and first time being pulled over :D Not too bad...
I had my bar prepped before I picked it up... seems ok to me, i might touch it up a lil before it get painted...
lol - ok Zen Grasshopper.. that leaves it nice in the open!
Did you have a chance to test fit the bar? Look good? Its very hard to tell until its actually on the car though all painted. My old bar i saw at Palm unpainted but fitted and it looked so-so. When i got it back it was unbelievably shiney and everything :D
I still have to sand the other skirt back tomorrow.. i even had to cut out the "speed" holes in my new sideskirts as they come out of the mould filled. Took a bit of work.
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
