  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Charly - Yeah I am a "Junior Manager (IT Superviosr)" for the IT Department at Langs Building Supplies, Yatala, just around the corner from the BP :D But I actually do the following things, Database Admin/Netowrk Admin/Phone system help/IT Helpdesk/Computer repairs and setup/Printer Repairs/anything that is electrical repairs :) Which is why you see me post so much here, because I have one code windows and one SAU window open at all times ;)
Yupp, explains the bicycle everywhere, so miss my line, sooooo temped to call up Gav to see if he's had a look at it yet, but know what the answer will be, no because they are flat out, and really do not want to bug them about it, I know they'll ring me, just going crazy thinking about it, waiting for the list of things needing to be replaced and the the price.............not looking forward to that bit! :D
sounds remarkably similar to what I do except most of the the purchase and fix stuff tasks are in addition to my actual job. After about two weeks with no car I would be going mental too. I really hope the weather continues to hold out. please tell me that it's not raining on the coast right now.
I'm scared to call, maybe HEROMAN can save the day,............. or maybe I should get off my scared, lazy ass and give them a ring, yeah option 2 I think is better, dont like people who wear tights, esp men, eeewww!!
Or those who wear their underwear on the outside :flower:
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
