if you can get him down to 500 for the trust zaust id get it, the muffler is gonna come up at an angle if im looking at the way the hangers are mounted, but also notice that it has a small "hotdog" style resonator, which will quieten it a little and make it less noisy as opposed to my dirty great big rice cannon which deafens small children and the us military accused me of stealing the gun barrel off one of their tanks
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
looks ok.. don't forget postage costs will be steep on an exhaust.
Which is why I doubt it he'll sell it to me for ~$500 INC the postage, but we'll see how low he is willing to go and if he can wait a few months and i might be able to scrape it, maybe in May :)
i would also like to say
http://www.skylinesaustralia.com/forums/sh...ead.php?t=35694 those boots that this guy makes are freakin awesome, i have em in my car and im tempted to buy a spair set just incase the ones i have ever wear out
Yeah I saw them, awesome price, but atm need all the cash I can to scrape through the cat back, but they are on the list, certainly cant buy crappy vinals for that price, and they are leather!
I recently installed a set in mine. They look great and workmanship is top notch
Yep one of my first mods too... Only needed the handbrake boot as I'm the only QLD'er with an auto.. :)
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
