Good thing about the trust kit is you can bolt it up .. comes with *everything*.. the little brackets, screws, even a replacement washer bottle if used in conjunction with their front plenum.
Guy in melb did it in one night and about as mechanically minded as me (not much).. so install is 0 dollar
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Well I have a definite roadmap to follow, but after having a good look at R33 GTR prices lately I am thinking of maybe abandoning the project and investing (if such a word can be applied to cars) in the GTR
yeah.. definitely -- if you have money to spend may as well put it to a GTR.
With me as my car came with most mods at a price not too much more than your "average" gts-t.. i saved a heap there.. but to be honest now I could install what is on my car myself so i guess that takes a lot of it out. The costs of labour on some performance items is a bit of a joke to be honest.
Everything i get somebody else to do something i get stung, i get angry and vow the next thing i am doing myself :rofl:
well there is always buy an m3 a couple of years old.. s2000 .. lots of nice cars out there now a few years old for under or around $50k :rofl:
GTR aren't the be and end all.. i've been in my mates GTR. Its fast, it got grunt but its still a "Nissan R33" you can never escape that aspect.
Guys i have a hybrid cooler and i reckon its just as good as the jap brand ones.........theres nothing wrong with the coolers, people just have the shits that the piping doesnt line up properly and it can be a bitch to install.
They flow just as good and is fine for street use. Unless you want a drag monster this cooler will be fine.
After i installed it the car felt much better through the mid and upper rev range and my knock levels went down quite significantely.
lol.. funny.. when i think i bought a whole 2nd hand car for less than the price of just an ECU or turbo purchase, i wonder sometimes.. am i losing the performance bug? today i drove 200km to the GC and back, it felt like i was driving a family sedan :rofl:
What can I say GTR's make me moist
the others don't..... meh
yeah....i feel the same sometimes...and let's face it, there aren;t that many opportunities to use the performance value to its full potential these days, but could you really see yourself being happy driving a barina??????......maybe one day
frankly, I am holding onto my licence by such a tenuous thread that i really should be driving something like that.......:rofl:
agg! bad image there :rofl:
hmmm, for some reason whenever i see an R32 that does the same to me, 33 is shrug. I think i need to go into skyline therapy.. the love for the r33 has gone :rofl: noo!
I personally wouldn't go for the HYBRID because I have been told to steer clear of them. You mose well have your standard cooler there because it flows about the same. They are cheap, but you get what you pay for.
I am saving up to buy the Apexi GT cooler. I really like the look of it and the size.
But that's just my 2 cents.. you may not agree.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
