  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
haha - If you could only choose one who would it be. I would take Mary Anne if there had to be a choice. farmgirl nextdoor type
lol.. i can see this as an upcoming question on "who wants to be a millionaire".. i'm leaning towards ginger.. just because redheads are more crazy :)
Yeah...that's one of the things I miss about living in Sydney...it was like a 35 min drive to work, and there's nothing like the take-no-prisoner, cut-and-thrust of Sydney traffic to wake you up in the mornin
really? you crazy! i did it a few times in melb, the whole urban grind, sit in traffic bumper to bumper.. driving a manual at that :)) all the way for the 1hour trip to the city (which was only 40km anyhow). No way!
haha.. The joys of pregnancy hey Warrick?
I'm used to it now, andrew does it every weekend. I actually find it quite soothing now and i can't sleep without hearing it :S
lol....I wish my partner was as understanding....but alas NOT!
yeah....but if you leave a bit early with the rest of the crazies, the roads are a lil less congested and there's a bit of room to "move" (read: duck and weave like a maniac)
i choose "bam bam".. in the older episodes... when she was a cheeky teenage girl ! truly :)
ok, this topic is only going to quickly degrade :D
Bam Bam huh.....well each to their own
me... I preferred Pebbles when SHE was a cheeky teenage girl
I personally wouldn't go for the HYBRID because I have been told to steer clear of them. You mose well have your standard cooler there because it flows about the same. They are cheap, but you get what you pay for.
I am saving up to buy the Apexi GT cooler. I really like the look of it and the size.
But that's just my 2 cents.. you may not agree.
I actually have one on my car and it performs very good. Changing from the stock cooler to the Hybrid made my boost level pick up (in plenum) and does wonders for the cooling. No worries at 1 bar at 35 degrees.
S.
Isn't it disappointing to remember back to looking at those women that were so much hotter when you were younger.. then look at the reality..
LMAO....so true...as with many things from your youth
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
