  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I reckon Club tshirts should have our forum names on them so at meets you know who everyone is :P That's why i wear my SKA tshirt to meets, but I guess i dont really need to, or maybe I should print a shirt with "Island Boy" on it, then i might be a bit more reckognisable :D hahahaHa hAhHAHhAHHAHA haHAhAAH haha!
rain pours down and **** .. its like wet
Yeah water is usually of the wet kind :P
and my ****ing sunroof leaks now!!! its bullshit tryin to drive with 'drip, drip drip' on your head
its bullshit
[/rant]
baah!
That's why I do not like sunroofs, mate had one and can you say rust!
I reckon "Gilligan" would be way cooler :)
I've had that as a nickname before, I like Ska better, funny when iam wearing the tshirt clubbing girls come up and say, "WTF is S K A?" and I say no it is pronounced scar and if you dont know what that it stfu and piss off teeny bopper!
not bloody likely to be you dats for sure!! :P
lmao....thank fu(k for that :D
I'm gonna be a pansy and bring the all wheeler....haven't had a chance to find the wet weather limits in the 'line, and bald crap (nankang) tyres are not how I want to find it either.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
