i swear strutto we have to find someone that has a really worked auto 33.......there has to be people out there that have done it but ive had no success finding anyone on sau with heaps of mods on their auto. I dont think anyone has done any more work thats on sau then what i have
You coming to the dyno day in May?
Have to get your AFR's plotted and see where your at...
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
AFR's arnt a huge concern to me as i know the e-manage works 100% and even has more mapping points then the safc.
I just want to know if the ignition harness will work and how far the auto box can go
You should be concerned... You got the $$ to pay for a rebuild?
are you going to get your safc tuned properly on the dyno strutto? or just leave what you put in? Have you been driving this whole time with ur settings or put it back to zero?
Still got my home tune in there...
Will be getting the AFR's plotted at the dyno day... I don't think they will be doing any tuning for ~$35...
Will modify the tune further based on the AFR's it makes...
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
