  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hmm.. true.. thursday can't possibly be a rest day can it? :P
Maybe it can just be a meet then? I'm happy to find some nice routes and eventually plan one, just takes some time.
BAH who needs planning, I didnt plan my mountain run, I just pulled a UBD out and went that looks good!
really? I thought u might have known the route. I prefer to drive it first.. I have an idea that I went on when I first came to QLD. Down Goldcoast way. Its a bit hairy scary though.
Anyhow I've done the honours so at least people can argue about where to go.. hehe
but I have to remember which way it was :P lol
Nope never did it, so we did make a couple mistakes, like zooming past the first stop point at breakneck speed, blame strutto though I was the passenger and said, yupp we just went past where we were supposed to stop, oh well :P
*looking around for GenesisR32 Antagonist aka yamathu33
no more unquoted quotes from you eh? you lucky.. my usb ports died on my last night when JL came by my place to hook up his digi cam... been using alot of 'tab' just to type this msg :P
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
