yeah, i think that is one of the reasons I stopped buying phones. They moved from the simple to out of control with too much stuff I would never use myself anyhow. Good old 8210 is fine for me -- if i ever change i lose my old cheap workplan.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I loved my 8210.. Then I got greedy and wanted a colour screen one. I bought a GD68 and I've hated it since the day I got it and I can't upgrade until august or some shit.
****en stupid phone. I regret getting rid of my 8210. I loved that little phone.
I guess the lesson is that greed doesn't get you anywhere!
Hey warrick ;)
Umart is only part-time at the moment, chris hired another guy at the same time who works when I'm not working doing the same thing. Basically as he needs an extra person in there 6 days a week. But its worked out well so far, allows me to do other things.
Believe it or not I don't think he owns a skyline either ;)
but Umart has been good so far.
GD68 ? what brand is that? or has nokia changed their naming.
my 8210 had problems when i first got it, but after they fixed it been fine ever since. And i've dropped it, got it wet, i think thrown it, and it lives
warwick: speak in emoticons -- see whehter you can do it! ;)
I'm with you guys on the phone thing, I only upgraded from a 5110 to a 8250 lol about 6 months ago.
The more gadgets and crap they have on them, the more inclined you are to use them for pointless crap which just hikes up your phone bill
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
