  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
as pointless as posting in here altogether, but it doesn't stop you doing it does you charly? :D
ska: yeah, just spoke to ben then. Probably will drive his car down here (which would make things a hell of a lot easier) tomorrow to work, then can just drive it back sunday after the calipers are done.
I'll tell chaos as he was interested in coming down, to contact you for da lift :D
its gotta be 8am or earlier.. as i have to be here at 9am.. not sure how happy he would be with that :D
hmmm, the mystery continues: http://www.skylinesaustralia.com/forums/me...mber.php?u=9268 has an avatar but 0 posts, and visited this morning??? hmmmmm.
I just sent IT (lets just refer to it as IT until sex is determined) a PM :D lets see what happens.
Very very strange...
Heypred, how bout this, I will leave my car in the Garage with the battery on charge, you can pick up my car tonight when ever you like, take it back to your place, I will leave the jumper leads in the boot if it doesnt start at yours, and i can leave the charger in the boot also, not sure if you can charge it more at your place but if you can thats your choice.
So the only bad thing is if you leave work on saturday and the car dont start will you haveone elses car to jump start it?
    • That's it. Too rich for me. I'm out. If it does start to sell in pieces, I'll probably register an interest in the diff & axles, gearbox & tailshaft, and maybe the brakes.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
