  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
let me do all the work im capable of on it, from what i here it gonna be a beast, i love helping out on big projects apparently i have forsight (*sp) and this is what keeps me motivated says the shrink i was made to see at school
ah, another trobuled youth. :grouphug:
for sure dude im lookin at doin as much work as i can on it either myself or with mates to save cash.. im hoping in a few years..yes way ahead..that i can post some serious figures
i was an angry child, beat the shit outa too many people so i had to get anger managment counciling hence y i am now so calm and collected and not alot bothers me, my deputy head master used to call me marten briant, now do we all remember y he is famous?
hahahaha, it does actually, i used to do it every sunday morning for like the first 6 months of last year, had lots of family troubles and shiz, and it was how i relieved myself, just the sound of the car at 6 in the morning and the fresh air and the 120...130..140...150.... brake, then out to summerset off the clock for like 5 mins at a time. that was how i used to relieve stress it seriously was better then sex. Hope Kate doesnt read this.
I've really learnt to supress my rage also. I've found that not talking to everyone at work really helps. remember grant me the courage to change the things I can, the serenity to accept the things I cannot and the wisdom to know the difference.
I personally struggle with the second one, as I found myself screaming out my car window today at some F*ck1ng stupid tart who had an "I love animals" sticker on the back of the car but she was smoking with her infant child in the back.
Sweetart, hows about hou stop giving a shit about the animals and start caring for you daugther eh? Man that cuts me up. /end rant
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
