I was at gavin's today and noticed the phone was off the hook lol
getting my fuel pump upgraded next week and hes also putting my alloy bushes on :)
I was going to say that but I didn't want to. Its' very hard for them to do work plus run back in to answer the phone. So they just take it off the hook :(
Manda even does it sometimes if shes trying to do something important.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey ska, what u been doing? i fitted my stealth wing today. I only used sikaflex as what people recommended me and i didnt think it was gonna stick but man this thing wont budge hhahaha.
nismogirl its a whole ecu on its own. Its plug and play into the existing loom like the power fc which is great. So ill be ditching the safc which wasnt doing much anyway as it pulled my timing out and made my car misfire when boosted.
Then it sounds like another trip to willowbank heh
Hey MJ nothing much bumming round at work in and out of meeting after meeting today :) So what exactly does an safc do or what is it for? (I do realise that is a really noob question, but have had it explained serval times, still a bit confused......noob)
ska the safc is a air/fuel piggyback computer. It allows you to adjust the amount of air or fuel you want to put into the car. Nissan tend to make their ecu's a bit rich and when combined with a few mods the safc is needed to lean out the mixture to get a better air/fuel ratio.
This makes the car run better and give you more power and perhaps a little bit better fuel economy. Except that i dont have any form of timing control and when the safc gets leaned out the car will misfire due to the timing. So thats why i want to get a full ecu as this one is very limited in what it can do where as a wolf3d does everything :)
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
