  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
well just find a nice 33 gtst with coilover suspension and strut braces etc and youll be set :cheers:
im more into drag though, the twisties scare me :)
yea... i read abt you doing your bushes soon....
i wanted to do that as well but went for front and rear h/d sway bars first instead.
next up would be bilstein & whiteline springs combo.
it would be silly for me to sell it then :Oops:
by that time i should have done all the work i want to it and it will be time to look at a gtr :cheers:
everyone's getting a gtr.... GrRRrrrr.....
the maintenance aspects of it scares me though....
i think i will only go for it when i got myself a full time job after my studies....
the only problem with the conversion is you spend the 6-7k as you said and you wont get it back.
Think of the money you could get from selling your car now, probably about 13-16k ??? plus the 6-7k you were going to spend on it, works out to be plenty for a real nice 33 gtst
EXACTLY what i was thinking....
but i'm *ahem* a 32 man :cheers:
you just cant knock the potential of the gtr though glenn
with basic exhaust, pods, and boost upgrade you are looking at high 12's.
jlnewtons did 13.4 stock!! thats just awesome
i noe.... @ the expense of his stock clutch though :cheers:
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
