  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
make sure you wear a collared shirt and a tie as well Eug....preferably a tie that will go with orange
and black leather shoes....make sure they are clean as well...we may be stopping at a few establishments where dress will be scrutinised
u guys are having too much fun.... at my expense! :usuck: *pout*
just until the shit stops coming out of your mouth :D
I just felt an instantaneous and unstoppable urge to inform you that you don't just suck like a supersonic jet engine on high-octane fuel; no, you are the singularity and event horizon of Suck: The Supermassive Black Hole of Suck. Yes, your Suck is so powerful that nothing - nothing - escapes its pull. Oh, did I mention that you suck? Have a nice day, cheers.
wtf....just tried to donate points and it says there are none of this item left :D
Stop rubbing Rogaine onto your swollen manboobs in the hopes of growing some chest hair and come away from that window you are wiggling your ass out of in the hope that some passing stranger might be desperate enough to grope it for the first sexual experience of your life, and get in here so I can force-feed you a generous helping of Shut The **** Up... and have kneepads fitted already - you'll be needing them.
focus Adriana....focus!
and catch up FFS
Shut up or I will burst through your gimproom door, beat you about the head, shoulders and asymmetrical ****face with your Anal Destroyer Dildo Deluxe, drag you down the stale urine, dog shit, bodily fluids, and KY-Jelly covered hall by your single front bucktooth, bounce you down the stairs like a bloated blubber beach ball, past the hat stand that you're trying desperately to cling onto, through the front door of your hermit hovel, down the street filled with bemused onlookers for further acts of unparalleled savagery.
Hi Erin:wavey:
want some points?....I just stole some off Adriana :D
Hewwo! :wavey:
I'll work out how to do this points thing tomorrow.. for now I'm going to bed cause I'm hell tired!
Night everyone. May see you's tomorrow. Depends on whether brutis is invited I guess
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
