QLD Whoretown...
predator
 Share
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Anyone know how far you can drive on the fuel ligh on, i have braved 40kms before chickening out, i dont have a jerry can otherwise I would, so that I know :)
Hey I have an 32. I have driven between oxley and St Lucia 5 times after fuel light. (maybe 50 kms-also traffic) Also from Redbank to Gatton on fuel light and then around gatton campus for 1/2 hour (hairy-looking for my prac group) That would be a 100 kms, and that is at 140 most of way. Ran out for first time in my car few days ago, But my last car was a newie too and I ran out nearly every week without fail. Never had a problem with fuel pump.
Source of problem: first car on gas, so can just switch tanks.
Get gas then you can get km travelled after fuel light for every driving situation!!!
hey Anthony,   Hope you and Michelle had a good time out with us last night. :)
Had a great time. Thought it got a bit hairy a few times (and I was in the slow group) - but I love hairy. Getting springs and suspension done this week. Anthony has gone to Townsville for a holiday (leaving me with exams) Will you all be meeting at 7.30 at Milton macca's next Thursday. Gonna try and leave the kids at home, but they have become little skyline fanatics so may be hard.
isnt like the dirty petrol towards the bottom of the tank? like all the sediments n stuff?
so if u get low enough wudnt all that get into the special RB engine?? -_-
Saw ur car parked outside the childcare centre at UQ on Monday morning SXE32.
hey chris.. do you know if Couriers Please deliver to Melb? and i can I use the company account to do it on friday? :)
(I'll pay whatever it costs to do it).
I need a place to ship my sideskirts to somebody, but most don't take private deliveries (e.g. you need to have an account with them)
 Share
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
