QLD Whoretown...
predator
 Share
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
not much aye... lookin for an immobilizer/central locker... know of anythin?
yeah man as I said come see me I can get you anything you want a trade price.
Give me a call at work if you want. I can get it fitted at our work if you wish.
since I fitted the 3" dump pipe, when I go full throttle to the redline I get a pop/miss between about 5000rpm and 6000rpm, then it smoothes out and revs freely to the redline.
If I use half to 3/4 throttle it revs smoothly to redline without any problems.
Any idea what might be causing this and what I need to do to resolve?
Check ur fuel pump.
lol....can you get me one at a good price? :D
i dont know, but a second hand GTR pump shouldn't go wrong either. But yeh changing my plugs ment i was lighting a leaner mix.... ie. fuel pump flow rate was going down little by little till it dies
Hey Adrian....would the Z32 AFM mean I would need to retune the SAFC anyway?
Sure would... Won't give you any more power by itself... I've also heard the SAFC and Z32 AFM's don't work perfectly together... They are meant to, but don't...
Z32 AFM just has the ability to measure more airflow before reaching 5V...
PowerFC does not have exessive airflow cut BTW...
 Share
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
