started on project "diagnose misfire" today
changed the plugs from NGK iridium to plain copper ones and gapped them at 0.6
cleaned the AFM and foam in the pod filter
tried to change the fuel filter, but couldnt get the bastard out :(
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
if what you have done hasnt solved the missfire, take it for a drive, do a few ks and then pull the plugs out one by one and check them
if they are being fired properly they should be blackened
if you find one that looks like its brand new or not as used looking as the others, then chances are the coil pack for that cylinder has flogged out
you will need to replace that one
thats what solved my misfire problem
changing the fuel filter is a good thing to do.
did you have any success with project diagnose missfire?
Haven't taken it for a drive yet, so I'm not sure.
Got all the hose clamps off the fuel filter and then couldn't get the hoses off, so had to turn back.....got any tips?
all the plugs I pulled out looked about the same colour.....greyish....so it looks like the mixture is OK
Couldn't see any obvious cracks or anything in any of the coils, but that prolly doesn't mean much.
I'll take it for a drive later and see how it goes....if it's still missing I might wind the boost down a bit, coz since I fitted the dump and FMIC it seems to max at about .8 or .85 BAR
thats how i got them loose, usually over the years they have melted a bit and end up stuck on
yeah...I think that's what's happened to mine....makes you wonder how long it's been since the fuel filter was changed :(
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
