QLD Whoretown...
predator
 Share
fuel pumps are horrible things - especially on an auto tank (they are different n harder than manual ones) and with a fulltank of fuel. Paul was like help me out n put your hand in the tank for me cos your arms are skinnier and im like "nah uh i aint putting my hands in there"
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
nizmo: can we borrow you boyfriend.. ship him over...and we'll express post him back.. we swear :rolleyes:
with pleasure ..... oh n dont worry about the return post you can keep him LOL
:jk: well he's in the bad books today.
neil: i helped my mate install a trust kit in melb...he had a aftermarket bar.. took about an hour for most of the work. It had like every little bolt and screw to go in, and was very easy. He had an aftermarket bar which helped as there were no issues there.
But can depend on the kit i guess.
Hours? Mine took one whole day then the end hose fell off so it would get to 2/3rds of a tank n run outta fuel ...... and another whole day fixing that problem.
It's a Trust RSPL and the new front bar is a Veilside rip, should fit straight in nicely
man.. ok.. umart dodgy mechanic day mark #x .. we'll be able to do a heap of stuff in one day..
half the trouble is just getting stuff off/out.. once you know the tricks its easy, easy..
fuel pump took me a week or 2 to find out even how to open the fuel tank after that it was a lot easier
:werd: thats what I am getting at, it is cool if it fits the first time, but nothing ever fits right the first time with cars :rolleyes:
They are worse than computers.
yep autos are ten times harder to do anything on ..... and apparently we cant get rid of our boost cut and also our turning circle isnt as good as manual lines ..... have no clue why .... unless the boy is just feeding me B/S.
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
