  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
they carded it for a business? lol .. thanks for picking it up too.
camgear is somewhere on a plane from japan to sydney.. its going to get here about 3 days late i think for gavin to put it on during timing belt, etc.. so i'm going to have MJ's camgear. When it does actually arrive, he has mine. All worked out :)
Well it worked out for you but not fo me :)
Oh my Chris you really have dropped off the pace somewhat, must mean you got a life, DAMN YOU!
chaos 3930
Cyrice 2897
Genesis® 2655
BelGarion 2485
Lazy-Bastard 2353
strutto 2274
predator 2082
SmoothLine 1984
Nexus9 1937
TeamKrazy 1439
Hmmmmmmmm having Ben move in will mean I will be able to catch up to him, as I only have a work laptop which no one uses but me atm, as it has certain company info, so it is for my use only, meaning Benny boy will be without net access until I can get another computer organised :) looks like it is going to take a while!
chaos 3930
Cyrice 2897
Genesis® 2655
BelGarion 2485
Lazy-Bastard 2353
strutto 2274
predator 2082
SmoothLine 1984
Nexus9 1937
TeamKrazy 1439
If you want to call her that :)
I never cared about post counts anyway, they mean absolutely nothing
chaos 3930
Cyrice 2897
Genesis® 2655
BelGarion 2485
Lazy-Bastard 2353
strutto 2274
predator 2082
SmoothLine 1984
Nexus9 1937
TeamKrazy 1439
I don't even get a mention! Damn me and my 6 months with no pc!
    • Surely the cam timing is set to something stupid at low RPM?
    • Hi guys, Sorry to butt in and take it slightly off course, although still on the VCAM subject.  I had VCAM put into my Tomei 2.8 bottom end and I struggle to take off because the engine has very little torque caused by VERY low dynamic compression at 60psi. But once off the mark and especially on boost, the engine rev happily all the way to 8000rpm and makes 630hp at 20psi of boost on E85 at the rear hubs. Has anyone had any similar experience or any suggestions on what might cause this low compression at low rpm? I am in the process of converting it into a 8hp transmission and with this low torque, the engine would not even stay running until the throttle is opened to more than 30% and then I loose all vacuum.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
