  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Big Dramas.
Low Compression in one of the cylinders. After some investigation I found the previous owner was experimenting with higher boost after the motor was rebuilt last august. Trying for a bit of extra power. Unsure what the problem is as yet, I need to call up tomorrow and see if they have discovered yet.
Its a great car apart from this issue.
Big Dramas.
ah no sounds like it might of leaned out on that cylinder when they were f**king around with high boost, how many psi is it down from the other cylinder's is it
Mornin Peeps, what a lovely day, lucky I had to come in early to drop Benny boy off, musta had a power failure over the weekend at somepoint, UPS did good and shut the puters down, but they cant start them back up can they :D
Hey hey got my name to show properly!
ooOOooOOoo if super mods get access to the Store, that means that us normal mortal users might get access soon too?
That offer is still available squizz, all my existing points for the other user Ska to be deleted, I have PM and emailed Christian, but no responce as yet :(
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
