QLD Whoretown...
predator
 Share
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Big Dramas.
Low Compression in one of the cylinders. After some investigation I found the previous owner was experimenting with higher boost after the motor was rebuilt last august. Trying for a bit of extra power. Unsure what the problem is as yet, I need to call up tomorrow and see if they have discovered yet.
Its a great car apart from this issue.
Big Dramas.
ah no sounds like it might of leaned out on that cylinder when they were f**king around with high boost, how many psi is it down from the other cylinder's is it
oh no that can be a number of things burnt valve head gasket rings :D thats got to suck would hate to be him :Oops:
its got a really loud ticking noise coming from that cylinder. if you put a screwdriver on the manifold above it and listen, it sounds like a f**ked valve. we're going to pull it down tomorrow... should be fun :D
Mornin Peeps, what a lovely day, lucky I had to come in early to drop Benny boy off, musta had a power failure over the weekend at somepoint, UPS did good and shut the puters down, but they cant start them back up can they :D
Where is eveyone lately?
He he he he he Ben wont be able to post for a while, or I _may_ let him on at home for a bit, depends :(
Hey hey got my name to show properly!
ooOOooOOoo if super mods get access to the Store, that means that us normal mortal users might get access soon too?
That offer is still available squizz, all my existing points for the other user Ska to be deleted, I have PM and emailed Christian, but no responce as yet :(
 Share
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
