QLD Whoretown...
predator
 Share
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
who's Vin?? Yeah I was there last night... but you guys had already left (got Rob's message a lil bit too late). Was there with a friend.
What was I looking for?
Was trying to be discreet. but clearly it didn't work. (Cheebye).
yeah we got bored so we all went home.
:( mmm... cheebye.
did u wants points cyrus??? i can give u some
Yeah but later once we can actually spend them, wouldnt mind getting Ska back :D
Only around 1000 posts to catch Benny boy, hmmm I wonder how long that will take me considering he doesnt have access to my adsl at home yet :D
how do u donate points now?
I dont think you can, yet, I still think they might be playing around with it before letting people use it again.....?
you finished the KY Cyrus... bring it in slowly, Benji is still young.:D
No gonna be easy on young benji, he really got thrown into the deep end, he has to work with a bunch of neanderthal factory workers, and the work is not friggin easy, its tough physically and mentally as you gotta be pretty thicked skin to work with those types of guys, you know they all drive fords or commo's V8's and all drink beer and watch footy, NRL, and they all drag their hands along the ground when they walk, so he really is a trooper!
chaos  3978
Cyrice  2979
Genesis®  2658
BelGarion  2539
Lazy-Bastard  2358
strutto  2277
predator  2115
SmoothLine  2006
Nexus9  1985
TeamKrazy  1462
Eug  1351
NA_R33  1343
Charly  1123
you have been :Owned: James.
Who is this Vin u keep referring to?
Maccas would have toughened him up...
 Share
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
