  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i liked sau, i spent time organising cruises and shit but as of late ya turn up without ya car and people glare and stare
id have thought being round for a while on the forums and having turned up to practicly every event i could woulda ment i wasnt treated like someone driving a holden
guess i was wrong
go figure
ppl getting all fcuked and serious for what?
cause other ppl did a cruise and they were not invited?
cause some ppl wanna do slow crusies and others fast.
thats the issue there RITE THERE.
TOOO MANY PPPPPL
TOOOO MANY MEMBERS
there is no way anyone will ever be able to make everyone happy, it is imposible
oh yer ive certainly noticed that
constant source of amusement as to why im never out cruising anymore... do you lot not ****ing believe the pictures? think its a photo chop ??
whats the go?
oh yes and i know its stupid puting such a big turbo on a stock engine, guess i wont be able to drive in the mountains anymore, it might be too slow a car, heaven forbid i hold the group up *rolleyes*
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
