hmmmm
always problems when chasing power in my experience
the amount of crap I had to put up with in the S13 to get it to 225rwkw you wouldn't want to hear.
And after I sold it the guy who bought it wrote it off after four weeks, I was so upset for some reason :D
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah they get pretty hot, im still 'testing' i guess. i might move them if its a problem. gav seemed to think it was ok tho so i think they'll stay that way. i've actually cleaned up the hoses a bit too - hidden them (if thats possible)
i see you're bidding for a powerfc.. watch those second hand ones! i got burt a little. the hc was rooted but he gave me back 200 for it. and the ecu is an older version rom and doesnt do data logging thus the tune method gav is using.
Yeah just an EOI at this time.
More than likely get a new one from Nengun for $1100 with hand controller.
If the guy goes as low as I want, we will see :D
T & T sounds sweet. i guess im ready! cept tyres but i'll just let mine down a bit.
Yeah I was so close to a thirteen last week, except for the bald tyres.
I borrowed Jay's tyre pressure guage and thought I had let them down to 25 PSI, when I went to the servo to fill them up one was on 33psi and the other was on 31psi, so his guage wasn't quite accurate lol
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
