  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ok so if i go out and buy sickaflex and just use that to attach the wing it will be fine? I just spread it evenly under the wing and attach it to the car? and dont have to worry about screws?
If i decide to pull it off will it cause any damage to the paint?
Thanks all :P
u wont get it off teh paint, unless u angle grind it off :)
sikaflex is black
and we held the front bar onto a mates strawberry face 180 with that stuff
once it dried, it never fell off (to my knowledge)
Yeah just becarfull what type of sikaflex u get there are a few types because some do not set fully they stay soft :P
Teamkrazy my wing didnt come with the nuts embedded in it :P
i can see myself ****ing this up, so i might just goto a panel shop tomorrow and get them to fit it, this is the type of thing where i only have 1 go to get it right.......
try cut some screws and screw them thro the orginal holes and into the wing, and back that up with some mirror tape
i dont think i met you last night teamkrazy, i was cruising back from fingal with you, i noticed you still had your number from willowbank still on heh
nice car man
lol yeah i could not walk yesterday (wakeboarding killed my knee) so could not clean it
thanks for the comments :-) i remeber you next to me a few times, i dig the bonnet
Guest
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
