I was at gavin's today and noticed the phone was off the hook lol
getting my fuel pump upgraded next week and hes also putting my alloy bushes on :)
I was going to say that but I didn't want to. Its' very hard for them to do work plus run back in to answer the phone. So they just take it off the hook :(
Manda even does it sometimes if shes trying to do something important.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey ska, what u been doing? i fitted my stealth wing today. I only used sikaflex as what people recommended me and i didnt think it was gonna stick but man this thing wont budge hhahaha.
nismogirl its a whole ecu on its own. Its plug and play into the existing loom like the power fc which is great. So ill be ditching the safc which wasnt doing much anyway as it pulled my timing out and made my car misfire when boosted.
Then it sounds like another trip to willowbank heh
Hey MJ nothing much bumming round at work in and out of meeting after meeting today :) So what exactly does an safc do or what is it for? (I do realise that is a really noob question, but have had it explained serval times, still a bit confused......noob)
ska the safc is a air/fuel piggyback computer. It allows you to adjust the amount of air or fuel you want to put into the car. Nissan tend to make their ecu's a bit rich and when combined with a few mods the safc is needed to lean out the mixture to get a better air/fuel ratio.
This makes the car run better and give you more power and perhaps a little bit better fuel economy. Except that i dont have any form of timing control and when the safc gets leaned out the car will misfire due to the timing. So thats why i want to get a full ecu as this one is very limited in what it can do where as a wolf3d does everything :)
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
