  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
haha - If you could only choose one who would it be. I would take Mary Anne if there had to be a choice. farmgirl nextdoor type
lol.. i can see this as an upcoming question on "who wants to be a millionaire".. i'm leaning towards ginger.. just because redheads are more crazy :)
Yeah...that's one of the things I miss about living in Sydney...it was like a 35 min drive to work, and there's nothing like the take-no-prisoner, cut-and-thrust of Sydney traffic to wake you up in the mornin
really? you crazy! i did it a few times in melb, the whole urban grind, sit in traffic bumper to bumper.. driving a manual at that :)) all the way for the 1hour trip to the city (which was only 40km anyhow). No way!
haha.. The joys of pregnancy hey Warrick?
I'm used to it now, andrew does it every weekend. I actually find it quite soothing now and i can't sleep without hearing it :S
lol....I wish my partner was as understanding....but alas NOT!
yeah....but if you leave a bit early with the rest of the crazies, the roads are a lil less congested and there's a bit of room to "move" (read: duck and weave like a maniac)
i choose "bam bam".. in the older episodes... when she was a cheeky teenage girl ! truly :)
ok, this topic is only going to quickly degrade :D
Bam Bam huh.....well each to their own
me... I preferred Pebbles when SHE was a cheeky teenage girl
I personally wouldn't go for the HYBRID because I have been told to steer clear of them. You mose well have your standard cooler there because it flows about the same. They are cheap, but you get what you pay for.
I am saving up to buy the Apexi GT cooler. I really like the look of it and the size.
But that's just my 2 cents.. you may not agree.
I actually have one on my car and it performs very good. Changing from the stock cooler to the Hybrid made my boost level pick up (in plenum) and does wonders for the cooling. No worries at 1 bar at 35 degrees.
S.
Isn't it disappointing to remember back to looking at those women that were so much hotter when you were younger.. then look at the reality..
LMAO....so true...as with many things from your youth
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
