yer.. my brakes are ****ed.. need a flush too in the least. Never been done since i got it, could be the reason my brake performance is getting worse and worse as i think the pads are ok.
may be making use of your facilities in a couple of weeks, and some of your brain :)
no worries. it always fun to have my compound flooded with skylines :) i had 7 total yesterday. :headspin:
just need 2 bottles of brake fluid, a $8 flush kit from Supercheap and we are good to go :)
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Famous? why you ask that? I know most of the melb SAU crew from when i lived down there
cos ppl from melbourne ring me up about my car they ask..."has predator seen it?"
bahaha... no idea.. wonder who they were? lol.
glenn: sweet, sounds cheap.. i like cheap - need to do gearbox & diff also. Will let you know when i need to get it done. I only have hte street here and a tiny as driveway with no room to work :)
nope no idea...they ring me when i'm sleeping, so i'm kinda grumpy...n they go "uhmmm...has predator seen ur car??" n i say...i dunno he might have
i did nick's gearbox and engine oil as well. we had to take the front bar out so so that it will clear my ramps. Neil had a jack and stands but there was just not enough support beam on the bottom to hold it.
but i am sure you are familiar with taking out your front bar eh :)
Guest
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
