  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I reckon Club tshirts should have our forum names on them so at meets you know who everyone is :P That's why i wear my SKA tshirt to meets, but I guess i dont really need to, or maybe I should print a shirt with "Island Boy" on it, then i might be a bit more reckognisable :D hahahaHa hAhHAHhAHHAHA haHAhAAH haha!
rain pours down and **** .. its like wet
Yeah water is usually of the wet kind :P
and my ****ing sunroof leaks now!!! its bullshit tryin to drive with 'drip, drip drip' on your head
its bullshit
[/rant]
baah!
That's why I do not like sunroofs, mate had one and can you say rust!
I reckon "Gilligan" would be way cooler :)
I've had that as a nickname before, I like Ska better, funny when iam wearing the tshirt clubbing girls come up and say, "WTF is S K A?" and I say no it is pronounced scar and if you dont know what that it stfu and piss off teeny bopper!
not bloody likely to be you dats for sure!! :P
lmao....thank fu(k for that :D
I'm gonna be a pansy and bring the all wheeler....haven't had a chance to find the wet weather limits in the 'line, and bald crap (nankang) tyres are not how I want to find it either.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
