  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
is NOS ok for the engine though after sustained periods?
like short shots here and there are probably fine, but i've heard it kills the engine after a while unless the engine has been specifically built for it..
true or false?
its like winding up the boost gordo, the harder an engine works quicker it wares out obviously, same with nos, nos seems to have a really bad stigma asociated with it, but yeah its not that bad when used in correct proportions.
ok, i think i read (could have just been an uninformed post) that its the chemical composition that eats away the piston rings or vavles or something.. but that could be just myth. just curious..
depends how its tuned too i suppoose
yeah james, thats it really, yeah its the ones that were on the counter. No N2O is its inert (sp) doesnt eat nething, Nitrogen not sure ill find out (looks for last years chemistry books), oxygen, well that one definately doesnt eat nething.
there was a thread on boostcruising (of all places) and some people were discussing why not use pure oxygen instead of nitrous
but i think it was concluded that the oxygen plus the nitrogen's cooling properties and the fact that nitrogen carrys oxygen as well meant that nitrous was better than pure oxygen
and theres a bogan in a v8 strappin it up my road
yer..probably a myth.. its probably just detonation caused by poor tune that causes probs, then they blame the nos for destroying their engine.
ben: good luck with the loans, but remember, every loan you apply for goes on your credit record. Basically other banks in a way use this to assess the loan application. So the more loan applications you are refused, the less likely you will get one.
A loan of $12k is also a lot for a young-ish guy with no previous credit history, and you would definitely need a fulltime job and around 3 months of being there. Just wait, you will get it..
There was a lot of waiting before i got my r33..
Guest
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
