  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
almost mj, almost!
so did u say that gavin will also do your camgear?
i am keen to pull off my timing belt cover and see the condition of hte belt (so i know how much longer i need to replace it.. like another 5000km could be fine, or like NOW.. stop driving it completely, etc). I am thinking maybe if i get that far, i will just install the camgear.. then take it to gavin to adjust and do a full dyno tune.
Nah i wont get gavin to do my cam gear as its too much of a pain in the ass. I goto APC to use the dyno. Im thinking does it really need a dyno tune, ive searched the forums and it seems everyone with a camgear puts -4 and gets good results. So maybe if we just put it on and set it to -4 it should be fine??
yer, that is what i was going to put on.. but leave cover off for later tuning on dyno as required.
if you want to do it same time, could be a good little project i reckon.. there is a good thread in forced induction on how to do it.
bed? thats a little extreme jamez.. although i must say i don't feel much better..
yer, i understand .. and I am cautious myself. if i fried my engine i would be very up a creek.
But reading the thread, and all the comments from people (some of which don't sound too much experienced with doing mechanicals than me) who did it themselves, i think its doable. I have the tools, thats easy. It basically sounds like, remove fan and shroud (and x-over fmic pipe in my case).. mark CAS position relative to cover and remove.. remove cover.. behind should be the marks.. one at 10oclock inlet side, and 2oclock exhaust .. rotate crank to TDC, this should be where the built-in belt marks align with these marks.
unbolt stock gear.. pull off.. bolt on new gear, bolt on.
do all up..
i am confident now reading all that.
yup, i better go order mine too.. without a gear could be kinda hard to do. Wanting to do it about 2 weeks time. IF we get to a point where we go "hmm, looking too difficult" i guess we give up and put it all back together. Nothing lost, knowledge gained!
meant to make a nice difference.. better off peak power, and helps the turbo to spool quicker and harder
Guest
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
