hmm... gotta earn enough points to change my nick... apparently i have been getting complaints already about not able to PM me becos of my registered logo thingy...
ahh ...... but where have the points gone?
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i thk we still have the points ... just that we cant see it....
the Store function is still there though.... so hopefully i can accumulate enough points b4 it gets disabled.
the forums were running really slow for a while during your absences. the bandwide was really congested... prolly due to the new feature......
I don't know I had almost 2000 points this morning plus 550 banked, now it says I nonly have what I have already banked and the other points are no where to be seen :)
if you have that much...i should be able to see you listed in the 'Richest Member' section.... but its not there...
maybe it HAS been disabled already...
uh-oh....
Guest
