  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
dont thrash ur car and you wont have to fix some of those problems immediately.....
fix ur headlights that should be pretty cheap,
brakes......well im not too sure but nexus' dba rotors were about 500ish
try redline gearbox oil, that stuff works wonders for nosiy gears
then it will be back on track agian
also as a temporary fix just pickup some stock 32 springs
Yeah i decided no more thrashing .. this weekend shes copped a beating .. so .. these days im planing to make it nice and keep it in a straight line
The headlight problem will possibly be a 2 srage problem..
1. Blown bulb, so that should be straigh foreward
2. loose contact .. so i guess im goin to pull apart my dash to get to it, ive never soldied before so i kinda dont wanna do it. so i guess ill have to take it to a shop.
Im going to buy a jack
Going to try and get my backseat to fit in correctly )its wedged up a bit for some reason
And that shoild hopefully be my monday
I dont know if my rotors need to be machined, they are a bit worn but i dont think its anything urgent? .. i could possibly change it at a later date?
Im on DBA's website so ill try and see whats what
is that how you even spell his name? ..
mj - im getting stuff under control now, you know that guy i was telling you about how we had 'issues' ..
well i just spoke to him and i realised it was a personailty clash and thats why we were the way we were.
but its all gone now, never to be spoken of again! :)
Does Byron Bay have anything going for it on a friday night? :O:)
Guest
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
