  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
and nicole messages again
You are the only guy I have ever met who winges when a girl is chasing you up and not the other way around! :D
how do you put a pick in your sig , I just get ?????????
Stuffs me I just upload it to my webserver then link it back using that insert image button :(
yup.... funny thing is.... learnt a few things about my car..... wrong plugs..... brakes meed fixing.... hmmmmm and what is that bp ultimate fragrance in my cabin.....sniff sniff
Didnt you just get your plugs changed by gordo at the caliper painting day a couple weeks ago?
And I get that petrol smell in the cabin a lot too, seems it is a dodgy seal somewhere I havent bothered to fix it as I think I'm used to it now, doesnt seem to bother me much, I get a lovely euforic feeling everytime I drive for some reason........ :D
Well I have to go ppls , gunna keep scrubing down my rims . at least I should be able to get them painted sometime this YEAR ........ !!!!!!! if anyone can give us a lift for the thing today , I have fuel money and am on the GC , call 0402220733 !!
Morning lads.  Sounds like you are having a few car issues there Nick.
Yeh mate, i guess its the inexperience and rushed decision with the car.... its running alright now but the spark plugs are wrong so in a few weeks its booked for a full service and a dyno tune
edit: fuel pump died
Don't worry, one of the first lessons learned when you start messing around with car is :- its nothing that can't be fixed with the injection of large sums of money.
In fact you can apply that to many things.
hi everyone and hi chris havent seen ya in a while, hows things?
Hey matt,
yeah been on the down low for the last couple of weeks.
Probably still will be until I can get a few issues sorted out unfortunately
you taking it to Gav's?
Guest
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
