I've seen a few show cars with the full white treatment. Looked good to me, but all a bit of personal taste. It does come up pretty bright and things.
seat retrim in leather would be pretty expensive -- probably around the $1000 mark from what somebody told me.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
green dash? just remember you gotta look at it every day so you better like bright green!
Thats why I did some of the other stuff but left that.. was thinking cherry red for the whole dash facia could be a little too much too handle on a daily basis.
na_r33: yeah.. when i buy a new door trim, i was going to play with the old one and see how easy it would be to retrim (at least the insert) myself.
yeah, i think as long as i take my time it should be alright, just gotta get the main headach out of the way first before i start to play with other things, but i dont mind driving with no door trims, i did it for a while when i was originally putting the stereo in, i felt like i was in a race car :D
I SWEAR I am going to kill those stupid Belgians who ever came up with X++ Code, BAAAAAAARRRRRRRRRGGGGGGGG! It is illogical, HOW THE HELL can 1+1=3? BAH frik it I'm gonna whore for a bit, nothin like whorin to relaxed my stressed brain!
I dont buy stuff from the truck that stops here, got sick once after eating something, well cant directly relate it to that as I was not feeling the best before, but still, bit paranoid about buying food that is been luke warm for hours..................
I'm with you on the lunch truck ska. The last thing I bought from the Salmonella van was a sausage roll, and it was pink on the inside. I spat out the mouthful I was eating and threw it out. I mean WTF? How do you get a sausage roll to be pink on the inside. I don't want to even think about it. Well, I'm never buying anything from that truck again.
Guest
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
