  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah james....boost comes on quicker and engine seems to rev a lot freeer
getting some popping in the upper rev range now, i think it's over-fueling (I hope, coz i don't really know what pinging sounds like), so the SAFC prolly needs a re-tune
I am hoping to get a cooler in the next few weeks (sshhh...don't tell the missus), so might hold of on the re-tune till then to save having to do it twice
Wouldn't mind getting someone with an experienced ear to come for a ride in the meantime, just to reassure me that there is no detonation though
mmm i was under the impression that when ur engine started pinging the check engine light came on, or mabey that only happens with a pfc,
I have NFI
the same thing (popping noises in the upper rev range) happened when I changed from a pod filter to a Blitz panel in the factory box....went back to the pod and it was gone....pretty sure it's the SAFC tune
i might go for a run up mt tamborine or mt nebo-glorious just feel the needs for the corners and its a lovely day. I dont have a mother so I just got another day off work :)
/me dances.
hmm car all clean and the oils are right, just need tog et this 100k service done next month, rego this month :)
perhaps get adrian or mj to have a fiddle with your safc settings, perhaps make sure its safe for the time being?
yeah...might call on hero boy to have a look next time he is about....don't have any dyno info with AFR's though so it would be stabbing in the dark a bit...
Guest
