Thats publically accessible now adrian you n00b.... Lucky it was at willowbank I guess.
I wonder if the cops have the tools like on CSI where they take a 120x120 postage stamp size picture and "enhanche" it into a 1024x768 32bit 100dpi uncompressed TIF and read the address of a prescription bottle on the other side of the room?
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
lol...at least there were no 'civilians' in that shot, unlike some of the others...
It's not MY car doing the burnout...
It's another 33 sedan... :)
Guest
