QLD Whoretown...
predator
 Share
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
left work this arvo and was driving up the street and the engine started to die, then come back to life, die, then come back etc...had to be something to do with the piping I thought, so stopped and checked all the connections to find that I had forgotten a hose clamp on one of the joins.
Managed to limp it home and attached said clamp and proceeded to take it for a fang. Boost seemed to be building pretty slowly and I thought...I know you get a bit more lag with a front mount but this is a bit much. Anyway...gave it a real bootfull and it started coughing and spluttering and died when I came to a stop. Had a look at the piping again and found the SECOND clamp I had forgotten altogether.
Luckily I had taken a tool kit with some clamps in it and was able to fix it on the side of the road, so is now all good.
Gave it another bootfull on the way home and there is a definite improvement.
Only problem I have now is when I get to about 5000rpm it start to pop and miss, but it was doing that after I fitted the dump pipe the other week, so I think I need to change the plugs or at leas re-gap them and then have the SAFC retuned.
.. always pays to have the toolkit in the car. I've had the same problem myself in the past. Except I forgot i had been playing with the piping the week before it happened :-s
only a very small amount...boost prolly comes on about 3 - 400 revs later or so
ahh... just curious as to whether it was noticeable, as i've never driven mine without an intercooler as it came with one. in fact i've never driven a totally stock skyline now i think about it.. hmm..
Guest
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
