started on project "diagnose misfire" today
changed the plugs from NGK iridium to plain copper ones and gapped them at 0.6
cleaned the AFM and foam in the pod filter
tried to change the fuel filter, but couldnt get the bastard out :(
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
if what you have done hasnt solved the missfire, take it for a drive, do a few ks and then pull the plugs out one by one and check them
if they are being fired properly they should be blackened
if you find one that looks like its brand new or not as used looking as the others, then chances are the coil pack for that cylinder has flogged out
you will need to replace that one
thats what solved my misfire problem
changing the fuel filter is a good thing to do.
did you have any success with project diagnose missfire?
Haven't taken it for a drive yet, so I'm not sure.
Got all the hose clamps off the fuel filter and then couldn't get the hoses off, so had to turn back.....got any tips?
all the plugs I pulled out looked about the same colour.....greyish....so it looks like the mixture is OK
Couldn't see any obvious cracks or anything in any of the coils, but that prolly doesn't mean much.
I'll take it for a drive later and see how it goes....if it's still missing I might wind the boost down a bit, coz since I fitted the dump and FMIC it seems to max at about .8 or .85 BAR
thats how i got them loose, usually over the years they have melted a bit and end up stuck on
yeah...I think that's what's happened to mine....makes you wonder how long it's been since the fuel filter was changed :(
Guest
