QLD Whoretown...
predator
 Share
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey JL lookin at ur gallery man nice pics, what sorta mini is that? my old man reckons his old mini cooper S could give my 32 a run for its money hehehe he wishes, quite a contrast in cars
Its a GT clubman. Its exactly the same as a cooper S but in the square nose body. Mine is a stocker so its not that quick but there are plenty or cooper s minis out there that would give stock 32s and 33s a run. Nothing beats them for fun driving though, you can throw them around like nothing else.
ah ok JL yeah the old ma reckons he was out running cops around cornors and it top speed of 108 miles an hour was reached on numerous occasions... all fibs i say hes lookin at a few to buy but fark there xpensive espically some of the restored cooper S's
Guest
 Share
    • Guess I should be hunting down one of these big ol ford units then for max flow ....  I've had fresh gas in mine and it was never as cold as it is now . The compressor could have been trash though, like I said I am one example with a bunch of unknowns.
    • I don't know if anyone was seriously suggesting a retrofit of an Echo compressor in place of a more-or-less working original comp. You'd have to change the hoses at the bare minimum to do so, and that will definitely add significant cost. I had to get my hoses modded when I did the engine transplant and chose to use the Neo's AC over the even older R32 comp. That was startlingly more expensive than expected for what looks like a simple welding job, and a massive pain in the arse when it turned to have a pinhole leak in the weld too. The Frenchie's kit is for people who have next to nothing of the original system or have more than that but some of it is a bit shit and better off thrown away than salvaged. If you've got 90% of the system, you just patch it up. Mine is currently degassed because it apparently has a big leak somewhere. If I find it is the compressor, I will be looking to take my spare comp to a shop to assess and/or recondition, rather than contemplating a retrofit to anything off-brand.
    • I went and got the aircon regassed in the Stagea today and asked the guy about the upgrade to the Toyota Echo compressor. He was saying it is likely not going to be as good. It is newer but smaller and not going to pump as strongly. And it would be better to try and get a new OEM compressor. He was saying that the improvements people are seeing may be more likely due to regassing the system. I thought it was interesting to hear. Going by the sticker the system in my car was last checked in 2015. Gas was at 50% which is apparently beyond terrible. Under 80% is where efficiency already falls apart. Anyways, with fresh gas the AC is now bloody freezing. I think it may be working a bit less hard as well. I need to drive it a bit more to try it properly. Previously on hill starts it would utterly bog down the car. I'm hoping this is a bit better now. The frenchies kit looks great, but $1400 for the compressor upgrade alone makes it a bit of commitment. Very much so compared to a $150 regas.
    • Yeah, this shit is the reason dry ice blasting was invented.
    • Sweet thanks mate, I did wonder if its easier to try and find a R33 knuckle and make that fit, is it just a case of changing the lower ball joint? I'm getting drive wheel speed off the gearbox speed sensor which is fine so far to 230kph
