QLD Whoretown...
predator
 Share
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Guest
 Share
    • Suspension bush. Got urethane bushes in the upper arms?
    • thanks for heads up on actuators - will sort something as back up or solution as yes dont need that have enough trouble but no doubt some addition of something to spares boxes is required yes have a clue about WTAC but nothing has been officially put out yet so will wait to see exact details Pro class is, has been and will become a draw card for lap records and one off builds for show and thats about it I think - be interesting to see how open they make it Pro am is the old Pro in reality Open class will be split into 2 with slicks and 050's with no doubt slight variances in allowable drivers and changes in aero Clubsprint + apparently a true street class   They have to and are refreshing it all and bringing things up to current standards and need to 100% adhere to rules because whether people like it or not / or say it or not - for alot of competitors it is sheep stations and has been for a while when Im getting told I was illegal because i cut my rear bumper too high and yet others where in the grey areas of legality with everything from engines, suspension, ride heights and more serious influences it actually got quite out of control and heated this year so as much as I may be impacted by some of the changes and prob spit the dummy when I have to spend money changing things I think its a good thing for all
    • I can’t tell if it’s suspension related or maybe wheel bearing or motor mount.  IMG_6209.MOV
    • Start with a multimeter, and see if you're getting power at the TPS. There should be a manual for your car somewhere on these forums and it'll have the info for what closed TPS signal voltage is, and how it should sweep to full throttle. Same as for other sensors / valves.   Have you checked things like your base timing etc? See if anything looks amiss there too?
    • here are 2x options to consider: https://www.selby.com.au/price-promise/tonewinner-sw-d6000-subwoofer.html https://www.apollohifi.com.au/svs-pb-3000-ported-subwoofer-black-ash-pre-order.html I'm waiting for a good BF/CM sale and will pull the trigger on a new sub, I do like the SVS PB-3000 (13") but you could nearly buy 2x Tonewinner D6000s (15")
