dont like the 400r bar
im happy enough with my mspec bar, it has a much more agressive look to it than the standard skyline bar i think
i still have reinforcement in my front bar, just not in the area behind the numberplate mounts, i had to nix that so i could fit the cooler in
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yer well ive been told they are starting to become hard to get hold of unless you know where one is
i dunno i dont like the veilside bars that they make for skylines, im pretty picky when it comes to body kits, then again i like the stock look, it just needs to be lowered
neil the driver in the red suit is the d1 driver who blew out a tyre in melb and looped the skyline he was drifting twice, before regaining control and drifting the corner with an arm out the window.
on his left is the guy who won the melb factory class drift comp and im on his left and on the red flame suit's right is another drifter who used to be a regular on here (he had a silver 33 with bling bling wheels) 'mre'
Guest
